Don L's pics- working on the 25-45 Crossmotor
Mike Schotte
05-28-2003 16:53:22
Don L. sent me some pics of the inside of his 1925 25-45 Case crossmotor today.
I'll post them here- but let him post with the descriptions:
PISTONS
third party image
SLEEVES
third party image
O.K. Don- I know you won't reveal your secret parts sources... but how in the heck are you going to come up with a 78 year-old head gasket??
-Schotte
case poor in pa
05-31-2003 07:31:02
 Re: Don L's pics- working on the 25-45 Crossmotor in reply to Mike Schotte, 05-28-2003 16:53:22
whats the blue can for in front the pistons. some sort of afterburner? or air cleaner?
DON L
05-31-2003 10:45:16
 Re: Re: Don L's pics- working on the 25-45 Crossmo in reply to case poor in pa, 05-31-2003 07:31:02
Just as LES stated, I found it in the ditch and use it to show the relative size. Just go ask the Czar,[ the junkyard dog ] he'll back up. Don L.
Terry Nelson
05-29-2003 14:55:01
Thanks for the pictures and the commentary, Mike and Don. Looks like you won't have any excuses for missing the Almelund show, Don.
C. Amick
05-29-2003 07:34:06
Assuming the beverage can is 4-3/4 inches tall (standard 12 oz. can), I calculate the piston diameter to be 5-1/2 inches. Am I close?
DON L
05-30-2003 05:16:51
 Re: Re: Don L's pics- working on the 25-45 Crossmo in reply to C. Amick, 05-29-2003 07:34:06
yes they are 5 1/2 inch bore..... ....
Don L.
DON L
05-29-2003 05:08:57
The pistons look great, ring lands are like new also. The sleeves are shown right after I honed them, and not yet cleaned. We used hot soapy water ,as gas and other solvents will push the gunk in the sleeve, and soapy water draws it out. The sleeves have no ridges at all.../..notta. Bearings look like new, the engine in general was very clean, no gunk. But did have a 3/8 of a inch of gunk evenly on the bottom of the pan. Head gaskets are custom made, as well as the manifold gaskets. Willaim D. and Dave F. both told me to use manifold gaskets without metal, as it will rust and break the manifold flanges. The pistons and new rings went home last night. Take notice of the circle half way down the 16 inch long sleeve, that is where the oiler feeds the piston. The bearing caps were installed as well. The top 3 inch of the sleeve is combustion chamber, and has a beveled step to get the rings compressed in the chamber. The huge oil pump did have a blown gasket on the cover plate, which we made from the thick paper on the back of a tablet paper. Interesting to see that one of the oil pump gears is solid brass. Oil pump went home [in the tractor] last nite as well. That is my Buddies shop !!!! not mine .... mine if full of ????? {Case parts in a heep}.
Don L.
Thad
05-28-2003 18:10:30
Looks like a real interesting piece. But im wondering how much work is getting done with those extra cans of good beverage around. Looks like you have it under control it looks just a bit bigger than my LA. Have a good one Thad.
Les
05-28-2003 18:16:46
 Re: Re: Don L's pics- working on the 25-45 Crossmo in reply to Thad, 05-28-2003 18:10:30
I'm sure that can was one he picked up beside the road and is just there to show relative size.
Mike Schotte
05-28-2003 18:32:42
 Re: Re: Re: Don L's pics- working on the 25-45 Cro in reply to Les, 05-28-2003 18:16:46
Of course it was... As you know, a 12 fl. oz. aluminum can is the perfect benchmark for comparitive analysis of size and volume. (grin)
CASEPOWER once did the same thing, as I recall:
third party image
-Schotte
CASEPOWER
05-28-2003 19:29:23
 Re: Re: Re: Re: Don L's pics- working on the 25-45 in reply to Mike Schotte, 05-28-2003 18:32:42
third party image
Yea and you see what I drink. It would only take that one beer in Don's picture to put me asleep. Heres the same rusty tractor thats showing the chains.
Les...fortunate
05-28-2003 17:53:56
If anybody can do it, I bet he can!
