David Brown idenity
Hunter
05-28-2003 06:39:32
Found a DB tractor that looks to be the same size as a 400 Case. What size or series would this be? Also the owner says the lift is getting weak, any help will be appreciated> thanks
Elmer
05-28-2003 17:30:56
 Re: David Brown idenity in reply to Hunter, 05-28-2003 06:39:32
You may have comeacross a 1200 David Brown. There were alotof models made. It likely has a worn hydraulic pump. I have one in stock if needed. The serial number is on the right side of the frame at the radiator on the top side.
