VAC serial number
Henry Pane
05-23-2003 07:56:28
I just purchased a Case VAC tractor--all info I have seen tells me the serial number is on the engine block--the number stamped on the engine block is 72E-07244 the block number is VT328
I have yet to find this serial number on any list Can anyone help me
ACEd
05-25-2003 13:46:50
 Re: VAC serial number in reply to Henry Pane, 05-23-2003 07:56:28
I just found something tat may help - VAC Nebraska test tractor s/n 5258733 with high compression motor s/n 72D073112 - tractor was a 1948 tested in 1949. The sister tractor with low compression (distillate or kerosene fuel) was 5258734 with motor 74B073113. Not sure what 74B or 72D mean, possibly versions, but appears from your motor serial number I would guess you are looking at a 1947 or 48. Configuration (tricycle, adj wide front, standard front, muffler position (orchard)) would be necessary to determine VAC vs VAI, etc.
Les...fortunate
05-23-2003 09:28:17
The serial # should be on a plate on the "dashboard". Mine is 5656680, which means it's a '52.
ACEd
05-25-2003 13:30:22
 Re: Re: VAC serial number in reply to Les...fortunate, 05-23-2003 09:28:17
Does the VAC have serial number steel stamped into trans / engine mounting flange like my SC's. Number is identical to plates, except one has SC at end instead of beginning - on SC its on left side where motor attaches to transmission and visible from top side of joint if you don't have too much paint.
Related question s/n - does any one know what the 3rd digit means? I know first 2 are year +4, and last 4 were sequence number, but my 52 is 5660111 and they only made about 9000 VAC's in 52 - "Full Steam Ahead" book says last S/N was 5609189
Henry Pane
05-23-2003 09:57:32
I do not have a plate on the dash--but thanks for the reply
Les...fortunate
05-23-2003 19:59:43
 Re: Re: Re: VAC serial number in reply to Henry Pane, 05-23-2003 09:57:32
If you could post a picture or three on here, there are some experts around (I ain't one of them) that could certainly narrow it down for you.
Mike from Canada
05-23-2003 12:39:31
sounds like youve got my problem. someone fixed up the old girl and lost her i.d. tag
if you can post a few pics of your tractor from 4 different angles (front, back, left, right). some of us can identify the year just by looking at it. (well, within a couple of years anyway).
good luck!
mike
Henry Pane
05-27-2003 04:07:41
 Re: Re: Re: Re: VAC serial number in reply to Mike from Canada, 05-23-2003 12:39:31
I will try to get some pictures--tractor is currently tore down for paint.
Mike from Canada
05-27-2003 14:17:34
 Re: Re: Re: Re: Re: VAC serial number in reply to Henry Pane, 05-27-2003 04:07:41
ok
if you want, e-mail them directly to me and ill look at them when you get an opportunity
[email protected]
good luck
mike
