Help: Case 831 ps and pto problems...
Tim L
05-23-2003 07:03:24
I could sure use your help. 2 Problems in a tractor I'm thinking about buying. I'm not at all familiar with the Case 830 and I need some help in knowing whether or not I can fix these economically. The power steering is "shot" which means it isn't working well but doesn't leak. I assume it is the pump... they claim it is still "drivable". What is the worse case scenario?
The second is about the PTO on the 831: in the e-mail they said " the PTO does not disengage- I believe I'm saying that right, it keeps spinning... " What kind of pto does the 830 have?
I know the devil is in the details and I need to go look at it myself, but It would really help me out to know what is "normal" for these machines before I go.
Thanks in Advance for any help! Tim
Tim L
05-25-2003 12:43:45
 Re: Help: Case 831 ps and pto problems... in reply to Tim L, 05-23-2003 07:03:24
Thanks for the Information guys! It helps alot to know what I'm looking at.
Richard Cook
05-24-2003 22:53:56
have a power steering pump and front sector if you need one
Jim Handke
05-24-2003 18:06:31
Talked to my brother about the steering problem. He worked on one when he worked for a case dealer. He drilled and tapped the plug on the side of the pump, covers the relief valve. The pressure tested at specs. Which meant the pump wouldn't supply enough volume. He didn't remember if they tried rebuilding, or just put on a new one.
Jim Handke
05-23-2003 20:38:58
We have never had a power steering pump go bad on a 30 series tractor. The problem has been in the steering sector. We tried to rebuild one on a 1030 many years ago, but couldn't get it like factory. The pto has a brake to stop it from turning. You must pull the rear housing off to repair that problem. Isn't terribly expensive to fix, just time consuming.
