Case SC
newpuller
09-27-2006 10:34:57
How can I get more power out of a SC? I"m pulling it and I"d like to get more power. Also, will a DC motor fit in a SC tractor? Thanx.
L.Lamp
09-30-2006 21:59:23
 Re: Case SC in reply to newpuller, 09-27-2006 10:34:57
I have a '44 SC with 3 11/16 M&W button top pistons and the 5617 head with all new valves and guides. I have not dino tested it for power, but it runs out of power in the 4700 pound class. I have 11.2x38 new Titan rear tires. It did well in the 4000 pound class but not 4700. I run antique stock with stock rpm. I am going pulling tomorrow, 10-01. I am going to lower the rear tire pressure to 10 pounds to see if that will slow the speed down enough to keep the engine speed up. I pulled 3 feet short of a CC in 4700# class. I tried to get it down to 3500# but could only get it down to 3570# without me, another 200#. I have no starter, generator, battery, and swinging draw bar. I have no fenders or foot rests and the rear end cover was replaced with one from an S. It has a working S PTO. The front weight was out too. The only thing I could get rid of are the front wheels, which I think would be a mistake. I have pressed ones, but the weight loss is not enough to let me do the driving.
C. Amick
09-28-2006 08:28:54
Are you running 3-11/16" button topped pistons? Are you running a high compression head? I think the casing number for the high compression head ends with "17".
CLIFF S
09-28-2006 13:56:52
 Re: Case SC in reply to C. Amick, 09-28-2006 08:28:54
Where do you get 3-11/16 pistons at? I have a SC that i Pull in the Barnyard stock class and it runs low in power in 4500 and out of power in 5000 and we can knot strip tractors in this class! I have 3-5/8 pistons and a high compression head and i too would like more power! Mine has 28 HP and thats knot enough! My Super C i use around the farm has 29+ Hp, I would like to build another Case SC just for Pullin in the 3500lb + classes, Is it Possable to get 40+ HP out of an SC ?
C. Amick
09-29-2006 06:36:12
 Re: Case SC in reply to CLIFF S, 09-28-2006 13:56:52
The only 3-11/16" domed pistons currently available are used ones. There is a guy working to get some in production. I sent him one of mine as a pattern. Do you have the lighter older style pressed steel wheels? Did you remove the weight that is below the radiator? How many RPM's are you turning? I think you can get it up to around 38 HP, but I don't think you can go above that without major engine work.
CLIFF S
09-29-2006 18:02:41
 Re: Case SC in reply to C. Amick, 09-29-2006 06:36:12
Sofar i only have a Nice Original SC that Has all it came with other than rear weights thats why its 4500 lbs with me on it and other than changing to a Distrubitor to gain some Loug and a Spring to help the RPMs to 2100+ i don't want to change this this nice SC BUT i was thinking of getting another and maby putting some 4" or Bigger Pistons in it and make a tractor that would compete with Farmall H with 350 IH engine and start out in 3500 and go up! What do ya think? Any other ideas for a Puller SC ?
C. Amick
10-01-2006 18:20:27
 Re: Case SC in reply to CLIFF S, 09-29-2006 18:02:41
I figure that you might have to bore the block to get 4-inch pistons in an SC block. I'm afraid you are going to spend a bunch of money and still not have a competitive tractor. The SC is just not a good choice for a pulling tractor. There are other tractor makes out there that have larger displacement engines with less weight. I think a Case VAC, DC, 350 roundnose, or a 400 roundnose would be a better choice. You can put the internal components from a 148 cubic inch Case engine in a VAC block and have a pretty good horsepower to weight ratio.
CLIFF S
10-02-2006 19:14:37
 Re: Case SC in reply to C. Amick, 10-01-2006 18:20:27
I Know others are better choises for Engine Combos and i have a VAC and it needs more than 19 HP Too! BUT my SC Will Balance out when others wont Like a DC dose! My stock SC Won a 4500 Stock 16 inch DB that they supply the Clevis Class the last Two times over an 880 Oilver and a Small 400 Case with Farmall H and JD B also in the Class and thats why i think with some Cubes and less weight it could be Competive from 3500 to 5000lb class And a Challange to make something no one else has!
C. Amick
10-03-2006 07:30:46
 Re: Case SC in reply to CLIFF S, 10-02-2006 19:14:37
At one time, I had thought about building an SC puller, but just sort of wrote it off after what I had read. I have a very old SC rear end (prior to mechanical lift)that looks lighter than the later ones. I figured that if I took out the PTO shaft, bolted it to a late model engine, and found some steel wheels, it might be competitive.
Walt Davies
09-28-2006 23:17:55
Yep! put in a 3/71 GMC lots of power and not much weight increase.
Walt
