Hydraulic Spool for 530 CK
AJ
05-21-2003 07:21:12
The spool is leaking and has been for quite some time. I just fill up the hydraulic fluid before I operate it. Just wondering if anyone had an idea of what a spool would cost. The spool is one solid unit. Is it worth the money compared to the cost of just dumping in fluid?
jimks
05-21-2003 10:35:10
 Re: Hydraulic Spool for 530 CK in reply to AJ, 05-21-2003 07:21:12
is the spool scored badly? You might be able to polish it up gently and replace the o-rings.
AJ
05-21-2003 11:01:31
 Re: Re: Hydraulic Spool for 530 CK in reply to jimks, 05-21-2003 10:35:10
I don't know. The person I bought it from, thought that the entire spool needed to be replaced. They actually had the ho off and were ready to do the work, but were told the replacement spool would be $3,000! I checked at a local tractor grave yard and they had a few on hand that might work and they qouted me $200. I'm wondering if the $3K was for a new or reconditioned part compared to used.
jimks
05-21-2003 16:13:36
 Re: Re: Re: Hydraulic Spool for 530 CK in reply to AJ, 05-21-2003 11:01:31
I think that what I'm calling a spool and what you're calling a spool aren't the same thing. I assumed you meant a spool in an open center spool valve... but if the price is $3k, then that's something else... what do you mean by "spool"?
