David Brown 990 Hydraulic pump
Rick Cook
05-21-2003 05:15:26
Can someone tell me if the hydraulic pump from a 1967 990 Selectamatic (white)will replace a pump from a 1963 990 Implematic (red)? (Elmer?) The rest of the Selectamatic is going to the great bome yard but if interchangeble, I may keep pump as a spare.
Also, is removal via the rear pto cover or is it a tractor split operation?
Any advise apreciated.
Elmer
05-21-2003 08:13:24
 Re: David Brown 990 Hydraulic pump in reply to Rick Cook, 05-21-2003 05:15:26
No the pump will not interchange. The control valve from the implematic is mounted on the top ofthe pump and the control valve from the selectamatic is in the right side of the axle housing.
Rick Cook
05-22-2003 04:50:11
 Re: Re: David Brown 990 Hydraulic pump in reply to Elmer, 05-21-2003 08:13:24
Thanks Elmer,
I had unfortunately thought as much :(
How about the injectors and pump?
Thanks.
Elmer
05-22-2003 05:06:51
 Re: Re: Re: David Brown 990 Hydraulic pump in reply to Rick Cook, 05-22-2003 04:50:11
Yes they will interchange, if the selectamatic tractor has the AD4/47A engine. Around 67 and 68 they introduced the 449 engine.
