Temp Gauge
Fred
05-20-2003 17:44:03
Instaling A new temp gauge on A 1950 case vac. Long ago someone cut off the capilary & screwed A plug into the head.I haven`t been able to remove the plug.It has A square head & Im`not able to get A wrench on it.Is there A tool or A way to remove it? Thanks for any help, Fred.
Slowpoke
05-20-2003 23:30:39
 Re: Temp Gauge in reply to Fred, 05-20-2003 17:44:03
Some of the smaller sockets are available in four point (square). You need to shop around till you find the size you need. They may be included in some of the low priced ($5) 3/8 import sets.
Joe (Wa)
05-20-2003 19:23:59
You might try the female end of a socket drive extension. A 3/8" ext will fit most 1/4" npt plugs, 1/2" ext fits 3/8" npt plug, etc. You could also try a 8 or 12 point socket if it isn't in there too tight
