Uh oh
Les...fortunate
05-19-2003 19:47:35
Just got an email from my young friend who's tearing into the SC. He says the clutch is stuck and he's going to split the tractor.
Good thing his mother doesn't mind sharing her garage with a rusty old piece of er, nice machine like that.
C. Amick
05-20-2003 09:45:39
 Re: Uh oh in reply to Les...fortunate, 05-19-2003 19:47:35
Don't get in a hurry. Soak it really well with some P.B. Blaster. The splined shaft is probably rusted to the clutch plate. After it soaks for a couple days, reach through the acces hole and tap it with something.
jal-SD
05-20-2003 06:19:32
Tell him to be REALLY careful-the front half gets real "tippy" when its separated from the back half. Gotta lock the front wheels straight some way, because when you take the chicken roost off, the fronts will turn really easy. We usually bolt a couple of 2X4's to the arm, w/bottoms deck screwed into a square wood block tightened into the square casting hole on the same side. Don L probably has the parts. Does yours have a front weight under the radiator? It weighs about 100#-use a hay hook & big guy to remove, there is a hole in it-look under the trash. It will come out w/o taking radiator off, but ya gotta be careful. (My $0.02 worth. jal-SD)
Les
05-20-2003 13:42:30
 Re: Re: Uh oh in reply to jal-SD, 05-20-2003 06:19:32
Thanks, jal. I'll pass that on.
See pictures in above post.
