Hydralic fittings Help
Tom
04-17-1999 17:55:23
My 90 degree L fittings are leaking on my Case DC hydralic pump. Does anyone know where I can get new ones and how much they are going to cost?? Male3/4, Female 1/2.
Thanks
Frank O'Meara
04-20-1999 22:42:08
 Re: Hydralic fittings Help in reply to Tom , 04-17-1999 17:55:23
Tom: Most of the time there are only three or four types of hydraulic fittings. If you take them with you to an hydraulic repair shop, PTO sales, large truck repair shop, some one there shuld be able to help you. I'm in the process of rebuilding a 1943 DI, but don't have hydraulics on it. I have a friend in the hydraulic repair business, and I do a lot of hydraulic repair where I work, but I'm to far away to be much help to you. Repair shops are just like any other bussiness, you need to find the right guy to talk to. One type of fitting has an o ring under it, which will leak with age. Also most hydraulic couplings also have o rings that sometimes will leak. Hope this information helps. Frank
charles
04-24-1999 08:51:57
 Re: Re: Hydralic fittings Help in reply to Frank O'Meara, 04-20-1999 22:42:08
Frank, I've got a question maybe you can answer. On my IH340, the 0-ring on only one of the fittings at the end of a difficult-to-get-to hydraulic hose end keeps blowing out. I use a 2000 lb plus pressure rated ring. It last from 2 weeks to 2 months. Very hard to loosen the fitting and later correctly re-align (no room and hose wants to torque it) and tighten it. Is this just a curse?
