Followup on case 600 transmission noise
Rick in MD
05-19-2003 10:37:28
I found the problem, It was the bearings on the inputshaft both were worn out along with the bevel gears. Someone once told be that the bevel gears and bearings were the weak part in the transmissions of the la,dc,500, and up. My question is is this true? I my self realy dont think so but wondering what have all of you found usaly worn in a case transmission in the sc,dc,la,500,and 600?
DON L
05-19-2003 16:17:04
 Re: followup on case 600 transmission noise in reply to Rick in MD, 05-19-2003 10:37:28
I find the same thing on the 500 and 600. Noisy pinion drives. I got a another 600 comin out of the wheat country that I hope is quiet. SSSSssshhhh..... I aske the seller to check it. My Detroit power LA's have quiet rear-ends....go figure.
Don L.
Jim M
05-19-2003 15:37:31
I bought and fixed up a DC that had a noisy tranny. The input shaft and first 2 cross shaft needed bearings. They used special heavy-duty bearing so make sure you replace with the good ones.
Bob
05-19-2003 20:13:00
 Re: Re: followup on case 600 transmission noise in reply to Jim M, 05-19-2003 15:37:31
I was the assistant mechanic doing the same job on L Case 40 odd years ago.
Problem there was caused by using belt pulley to drive 250 amp Lincoln DC welder. There was a tremendous sudden load each time the arc was struck. It chopped out the belt pulley bearing in no time and spread filings throughout transmission. Ended up replacing all bearings.
