Found reason for dry rockers.
Roger
05-18-2003 11:45:08
Pulled the head on my '66 430 188ci diesel. There are two oil passages in the block only the center is flowing oil. The head must be from a later model with the oil coming in the rear opening, center is not drilled. My question: can I drill the center rocker bolt hole through? I don't want to hit a water jacket
rory
05-18-2003 19:42:37
 Re: Found reason for dry rockers. in reply to Roger, 05-18-2003 11:45:08
Roger they where built both ways ,just put the drilled rocker bolt ti the hole that produces oil flow. some where center some where rear the rocker shaft dosen't care where it comes from just make sure you put the bolt with the hole in it in the right one for your situation!
gm
05-18-2003 16:37:13
Well, maybe you could tap it with metal, see if you can tell. Probably best to get the diagrams of it. Apparently, people use jb weld in there at times for cracks so you might be able to fix the hole easily if you hit a water line. -Greg
