Case backhoes 1960's models
John
05-18-2003 08:40:23
Does anyone happen to know where the hydraulic dipstick is located on the case Backhoe 530 construction king. Thank you very much.
Lloyd
05-18-2003 16:27:46
 Re: case backhoes 1960's models in reply to John, 05-18-2003 08:40:23
If it`s like my old 580 CK there is a pipe plug on the right hand loader frame about half way down. When oil runs out the hole its full.
gm
05-18-2003 16:26:09
just take the plug off the loader frame and if you can see fluid, you are good to go. It can get pretty low before you start having problems. I usually dump a couple 5 gallons in there once a year. Probably holds 15 to 20 gallons total. Mine probably has better than average leaks. Tearing everything apart to fix the leaks would be ideal but the oil is pretty cheap. -Greg
Scott from Hawaii
05-18-2003 09:25:55
On my 530 the backhoe gets it's hydro fluid from the main resevoir located in the frame.
