No oil at the rockers
Roger
05-17-2003 14:01:25
I just put the head back on my 430 after a valve job and the rockers are not oiling I'm sure I have the gaskets on right and the drilled bolt in the rear hole. Is there something I missed. Don't want to pull the head again.
C. Amick
05-19-2003 09:29:41
 Re: No oil at the rockers in reply to Roger, 05-17-2003 14:01:25
Does the 430 have the spin-on filter with the long stem that slides up into the filter? If it is supposed to have the stem and it is missing, it won't push oil on up to the head.
Thad
05-17-2003 16:05:02
Some blocks have the oil hole in the center also. But if it was in the back when you tore it down crank the eng over with rockers off to see if it pumps it up to the top. Have seen gaskets wrong and you can punch a hole thru it to get oil up there good luck. Thad
