Converting hand clutch to foot clutch on 930
Ricky
05-16-2003 10:08:22
Can you convert one that is a hand clutch to a foot clutch? Thanks,Ricky
Allan C
05-16-2003 20:30:09
 Re: Converting hand clutch to foot clutch on 930 in reply to Ricky , 05-16-2003 10:08:22
You would have to change th pressure plate as well as the linkage & probably the fork. It would be a split job. My question is why would you want to? In my opinion a hand clutch is the superior setup unless you've got a loader on it.
Jim M
05-16-2003 20:29:01
You can convert anything it's just a matter of how much you want to go through. My dad has a foot clutch model that he will sell you all the parts you need to do it. Will have to look at the book to see what all has to be changed.
John Saeli
05-17-2003 05:45:35
 Re: Re: Converting hand clutch to foot clutch on 930 in reply to Jim M, 05-16-2003 20:29:01
Jim; That foot clutch of your dad's, is it a 6 speed or an 8 speed? I can't remember if CASE built any of the last 6 speeds with a foot clutch. I converted a "52 DC to foot clutch, I had to get all the linkage, pressure plate, clutch plate and input shaft sleeve & carrier.
Jim M
05-17-2003 17:54:41
 Re: Re: Re: Converting hand clutch to foot clutch on 930 in reply to John Saeli, 05-17-2003 05:45:35
Yes the 930 is a 6 speed chain drive model. It is a 1964 year model. He also has a 1965 930 foot clutch also. I looked at the book and found you have to change the flywheel,cluch,pressure plate, and all the control mechanism. We can't guarantee the clutch and pressure plate condition but would remove and sell all that is needed for $300 plus freight
