Model 300 carburator
Terry Hentges
05-14-2003 13:03:23
My carburator has never been off the tractor.
it looks as mess. I am sure it needs re-built or at least cleaned up.
Is it very tuff to re-build, can't be much to it?
Where might I get a kit and some instructions or send it to someone to re-build. The re-build seem to be awful expensive and the new ones are even more auful in the magazines I have read???? Some companys only want to give a peson 25 bucks for the core? I think they are worth more then that.
Thanks
Mike Johnston
05-14-2003 21:35:08
 Re: Model 300 carburator in reply to Terry Hentges, 05-14-2003 13:03:23
Is the carb a Marvel-Schwebler (sp)? I just went through mine with a kit from The Carburetor Shop (see link below). If its the M-S carb, there is a brass tag on one side that will have a model number, such as TSX-635 or similar. You will need this number when looking for the kit.
Very simple to go through.
kennyp
05-14-2003 13:52:35
I agree carburator prices seem to me to be way too high. Not much to working on them. Just go slow and be care full not to twist off anything that won't unscrew. You will all most always need a new gasket. Next thing is a float valve (needel and seat). You might find a "kit" which will enclude these things. I have gotten by with old ones. Clean parts up good. Any automotive parts store will have a carburator cleaner, which is about a quart of special solvent in its can. Well worth the money. Use compressed air to blow all little holes clean. Oh yea, leave the butter fly valve part alone. Don't screw with its placement or you can cause a stickey idle. Good luck.
