SC single front wheel
Fredct
05-13-2003 19:23:44
Just curious - how rare are single front ends for the SC? Does anytign else need to be changed such as sheet metal etc. to adapt one to a regular SC or, does it just bolt on? Thanks, Fredct
Doug Franks
05-14-2003 15:31:26
 Re: SC single front wheel in reply to Fredct, 05-13-2003 19:23:44
I changed a 48 SC to single front. You have to change the casting under the radiator. This is because the part that the shaft from the wheel is shorter and the casting drops down about 4" lower than on a normal SC. Be sure that you get the casting when you buy
C. Amick
05-14-2003 09:27:30
They seem to be quite common in the northwestern states. Pretty rare everywhere else.
Mike from Canada
05-14-2003 00:27:40
as far as i know they just bolt on. uses the same linkage as a row crop front end.
mike
