Generator Brushes and Springs
Joel
05-13-2003 07:40:59
Hi all,
I am trying to find brushes and springs for a Delco Remy generator for my Case310c.
The model number of the generator is 1102 333
Serial number 4E 6
Any thoughts on where I can find the springs and brushes?
Thanks,
Joel
PS> The two terminals on the generator are not well labeled. Any way to tell the postive from the negative? Also, any thoughts on how to tell the positive from negative on the voltage regulator? I want to be sure I hook everything back up correctly.
Thanks again,
Joel
INCase
05-13-2003 10:19:21
 Re: Generator Brushes and Springs in reply to Joel, 05-13-2003 07:40:59
There was just another email like this for an autolite starter. Since Delco and others made nearly the same unit for several equipment manufacturers you may be able to get some things from other brand dealers if handy. I found NAPA to be difficult to cross reference and more $$ than the JD dealer for my 730 starter. Also if you get in a real pinch try Elkhart Starter and Alternator 574-293-2196. Also agian there have been some "info" sections on the home page in the past that talk about different types of generators and gives some basics, with pictures, of the wiring too. try the search area to find this. Good luck
klyde
05-13-2003 10:07:16
Armature post goes to a brush. Feild terminal goes to the feilds. There is no negative terminal, the frame takes care of the ground. Try NAPA for the brushes and springs or any of the local automotive parts places that have been around awhile. Reguators are usually marked GEN,(same as A or ARM) BAT or B (for Battery) F (for field) and L (for load or lights) Hope this helps
Joel
05-13-2003 10:33:56
 Re: Re: Generator Brushes and Springs in reply to klyde, 05-13-2003 10:07:16
Thank you for the help,
I'll take a closer look when I get home. It's apart on my workbench.
I tried autozone, pepboys, NAPA makes sense, those guys are usually more skilled.
My springs look, if it's possible, to be original, they are junk with one being broken.
Thanks again,
Joel
Glenn
05-13-2003 19:06:17
 Re: Re: Re: Generator Brushes and Springs in reply to Joel, 05-13-2003 10:33:56
I buy my parts wholesale at work from a company called H.A. Holden Inc they were bought out by a company called somthing like AES Parts. They handle many electrical parts for by gone equipment I find them a little pricy but they are exact replacement parts.
Joel
05-14-2003 10:12:37
 Re: Re: Re: Re: Generator Brushes and Springs in reply to Glenn, 05-13-2003 19:06:17
Thank you,
Joel
