Hydraulic hookup question
birdatwork
05-13-2003 06:54:07
My case 730 has 4 hookups. Two on the left side and two on the right side. One on top of each other. My question is can you hook a cylinder up to the top one on the right side and the bottom one on the left side? Or do you have to hook the same cylinder up on the same side?
The reason I ask is because I bought a new plow and it has small hookups. My case already has the correct size hookup on the top right, but I can't get to the bottom right very easily to replace it, so I was thinking about changing the bottom left.
sorry, sorry
05-13-2003 08:37:33
 Re: Hydraulic hookup question in reply to birdatwork, 05-13-2003 06:54:07
Whoops, I assumed right and left. Was on my tractors. I could be wrong. Every time I open my mouth some body sticks a foot into it.
top and bottom
05-13-2003 07:45:01
Top right and top left for one cylinder and bottom right and left for the other, unless it has been changed.
sorry
05-13-2003 07:32:52
Sorry, no. Assuming it is the usual open center type hyd. It might - might- work if you work both hyd levers at the same time.
