Trying to identify and troubleshoot a case tractor
Ranger Ric Sand
05-13-2003 00:55:15
I have the chance to buy a Case tractor for 500$,it has a front end loader that does not work, as well as the rest of the hydraulic system. They say it is a 1941 series 400 diesel case tractor. If anybody can help me to identify the tractor and or its value please reply. Does this year and model exist and if it does are there any pictures out there of one. This tractor does run but the brakes are weak. Thanks for any and all help.
Paul Janke
05-13-2003 18:56:17
 Re: Trying to identify and troubleshoot a case tractor in reply to Ranger Ric Sanders, 05-13-2003 00:55:15
I thought weak brakes on old tractors were required by law. Good brakes seem to be very rare.
John H-WI
05-13-2003 01:46:23
The Case 400 was not introduced until the mid 50's. Look at the dash and you should find a serial plate. If you can give us a little more info we should be able to help solve the model/year. You also might find a photo of it in the tractor photos. Do a search on Case 400. Does it have the headlights in the grill and is the grill flat in front versus round? Being a diesel it sounds like you could have a 400B model.
Ranger Ric
05-16-2003 23:52:52
 Re: Re: Trying to identify and troubleshoot a case tractor in reply to John H-WI, 05-13-2003 01:46:23
The Serial plate says model 400 no.#8068118. Any help you can give me would be great. It looks like I am going to buy this tractor, so I will be looking for some sheet metal eventually and some other part finding ideas, so stay tuned.
Thanks
Ranger Ric
05-18-2003 21:31:02
 Re: Re: Re: Trying to identify and troubleshoot a case tractor in reply to Ranger Ric, 05-16-2003 23:52:52
This tractor sat for many years, when it was started and moved to a trailer it broke the ramp and came down pretty hard. The Hydraulics worked prior to this incident, the tractor did not hit anything, just landed hard. Now the hydraulics do not want to work at all. Any ideas???
Ranger Ric
05-15-2003 19:48:21
I will look next time I go up there for a serial plate. As for the grill, it is missing as well as the bonnet. Thanks for the info, I believe this is worth 500$ as it is a running tractor just the front end loader needs to removed until the hydraulic problem can be identified and fixed.
Thanks,
