Hey Jim Handke!!
John Saeli
05-12-2003 10:24:02
Jim, What prevents the new solenoid from acting the way the original solenoid did ?
Jim Handke
05-13-2003 09:29:08
 Re: Hey Jim Handke!! in reply to John Saeli, 05-12-2003 10:24:02
That's a good question, John. And it deserves a good answer. And I don't have one. I got this tip from my brother who works for the green people. They double solenoid all their big tractors because they use too small a wire from the switch to the starter solenoid. It must have something to do with the starter solenoid being made heavier. Since I switched mine over, I haven't had any trouble with the starter. And it's been long enough that I can't remember how heavy a wire I used between the two solenoids. But it's pretty substantial. Let me know if you change yours over and what success you have with it.
John Saeli
05-13-2003 17:00:09
 Re: Re: Hey Jim Handke!! in reply to Jim Handke, 05-13-2003 09:29:08
Hey thanks Jim; The only tractor that bothers is the 1175. No problems with the 730CK, 870, 2096, 2094 or 4690. I use Group 31 batteries rated at 1000 CCA @ 0 degrees F. Some manufacturers are rating batteries @ 32 degrees F which gives a higher number. It's not comparing apples to apples.
Jim Handke
05-14-2003 20:12:35
 Re: Re: Re: Hey Jim Handke!! in reply to John Saeli, 05-13-2003 17:00:09
John, I forgot to tell you that I use a generic, run of the mill ford solenoid. Something off a pick-up. Cheap fix, you know. And my 1070 is the only one of our tractors that I had to do this. When we had a couple of 1030's, we had trouble with the solenoid plates burning and pitting. Thank heavens they solved that problem in the 70 series. I don't know why some tractors just don't get enough juice through the solenoid wire.
