Uneven Grass Cutting
Kurt Kramer
05-12-2003 08:45:53
I recently purchased a 1978 Case 446 Compact tractor. The problem that I am having involves the cutting deck. When I cut my lawn, the cutting deck fails to cut a strip of grass in the center of the path being cut(almost like a Mohawk hair cut right in the center of the path that has been cut!). It looks like I am missing rows in my yard. I checked the blades and all three are functioning. The width of the uncut row is around 6 to 10 inches wide. Any ideas?
Jim M
05-12-2003 09:43:58
 Re: Uneven Grass Cutting in reply to Kurt Kramer, 05-12-2003 08:45:53
Is the center 6-10 inches cut at all? If it is is it cut ragged or cut off clean. If ragged the center blade is on bakwards or turning backwards or has low RPMs. If clean cut check the front to back deck height. Back should be lower for that problem
C. Amick
05-12-2003 09:38:03
Could someone have put blades on it that are too short for the deck?
john m
05-13-2003 19:31:21
 Re: Re: Uneven Grass Cutting in reply to C. Amick, 05-12-2003 09:38:03
I agree with C. Amick. The center blade is longer than the two outside ones. Sounds like all three blades are wrong.
