DB 950 started my field on fire...
sebastian
05-11-2003 05:30:14
I drove my DB950 (diesel) through the field, looking back I saw fire! 2 hours later, 6 pumpers, and 5 burnt acres later I was left with a couple of questions...
seems sparks come out of muffler (can see em at night)...is this common? can this be fixed? Should i use it only in the rain:)???
thanks
case poor in pa
05-13-2003 19:22:11
 Re: DB 950 started my field on fire... in reply to sebastian, 05-11-2003 05:30:14
when ya seen the fire you shoulda backed up that D B and got off and run
Larry806
05-11-2003 18:32:40
A ol timers trick is to ball up some screen door screen around the muffler to catch the sparks Larry
Elmer
05-11-2003 06:32:34
Is your tractor burning alot of oil. The muffler must be full of crap to spark like that. There are spark arresters but where you can get one i am not sure. Your field must have been very dry!
sebastian
05-11-2003 16:58:55
 Re: Re: DB 950 started my field on fire... in reply to Elmer, 05-11-2003 06:32:34
It smokes for first 5 - 10 min. on morning startup. I noticed its only when at high rev's that this happens (sparking). Do you think a new muffler would do the trick?
BTW - Spring was really dry here, quebec canada. Things are just starting to green up now...
Bernard le m�cano
05-12-2003 14:13:17
 Re: Re: Re: DB 950 started my field on fire... in reply to sebastian, 05-11-2003 16:58:55
Hi Sebastien, i'm from Qu�bec too. I live near Rimouski. Where do you come from? May be your motor is not at the good timing, not advance enough. Bernard le m�cano Qu�bec Canada
