My CC pulling today. (picture)
CASEPOWER
05-10-2003 18:34:03
third party image
I have been working on it for around 3 months to get it ready. I took 1st in 3500# and 4000# super 12mph class. The hood still has to be finished but thats all. I weighed 3450# with no weights and couldn't run any on the front and thats why the front is up. But it's a Case so it still took 1st..
Earl S.
05-12-2003 10:17:37
 Re: My CC pulling today. (picture) in reply to CASEPOWER, 05-10-2003 18:34:03
We won Illinois State Fair 2yrs with a good running CC Case bored & stroked. 5500lb class. Keep up the good work. Earl in Illinois
Okla/kans Bill
05-11-2003 18:15:22
Ha ha I plow, or used to, I use my F-30 now, to plow, and the CC would bury itself highcentered, or boil over. I guess those short pulls supprise it and itds ovewr before it can do either. I love my CC, especially as mygrandad owned it, and its so easy to get on and off, but, with narrow 36in wheels, its not the best plow tractor lol.
Jerry
05-11-2003 13:13:03
Casepower looks good ,glad to see the case out in front. Working on a stock 400 that I just got running ,hope to have it at our fair to pull with it . Do you have any suggestions or things I should know
Jerry
DKase
05-11-2003 12:14:49
Nice starter on there!
John Saeli
05-11-2003 10:20:11
Looks good CASEPOWER. I was trying to get a closeup of that valvecover.
casepuller
05-13-2003 17:16:23
 Re: Re: My CC pulling today. (picture) in reply to John Saeli, 05-11-2003 10:20:11
what was the valve cover off of
CASEPOWER
05-11-2003 11:11:34
John Thanks for the valve cover. Without it I just don't know how I would have gottin that oil to stay in.
Mike Schotte
05-11-2003 08:43:16
CASEPOWER-
Looks great. I can't wait to see more photos of the tractor now that it's done.
Two questions:
1) How did the pulley "disc brake" that you made work out?
2) How do you decide the optimum angle for the wheelie bars to stop the tractor?
-Schotte
CASEPOWER
05-11-2003 09:02:30
 Re: Re: My CC pulling today. (picture) in reply to Mike Schotte, 05-11-2003 08:43:16
The brake works, but you have to make sure there is no drag on it when the clutch is engaged because it works before the final drives and takes alot of power away fast if it drags at all. The wheelie bars are simple. 1. make sure the total plate on the bottom is totally behind the cleat of the tire. 2. make sure they are no more then 10" off the ground 3. angle the plate so when they do hit the ground they don't dig in. Also put the bars themselves at a angle from the top of the rear housing. I have seen people just put them out level like the drawbar from the bottom of the housing and they bend them. Also if you do like me and use aluminum make sure you get someone to weld them that knows what there doing. I had LW weld them and he likes to over do things just incase and theres nothing wrong with that.
Larry
05-10-2003 19:20:33
Good going. I always like to see a Case do well at a pull. What kind of work did you do to the engine?
CASEPOWER
05-11-2003 09:08:08
 Re: Re: My CC pulling today. (picture) in reply to Larry, 05-10-2003 19:20:33
This is my temprary engine just to pull till I get my other one done so it's not much. I am running stock 260 cubes with high altitude pistons and a 5505 gas head with alot of porting. I had to mill the pistons .040 to clear the head. I also ported the manifold and knocked the guides out of the head and cut them so they didn't stick down in the chamber and hurt the flow. The other engine is much larger and I hope to finish it before the end of the year.
