David Brown 1200 3pt Hitch control vlv
Pat Downing
04-16-1999 15:12:12
I recently replaced the control valve for the 3pt hitch now when the tractor runs with the draft control in any position the arms raise and wont drop the control valve is free and movment is set .101 inch as scribed in the bottem. The hold valve is free and not binding the arms will drop if I loosen the cap on the hold valve.The arms wont creep up with the cap loose and the draft control works like it should but again the hold valve cap must be loose????
Elmer
04-17-1999 17:41:17
 Re: David Brown 1200 3pt Hitch control vlv in reply to Pat Downing, 04-16-1999 15:12:12
Latching valve may be stuck. It is the valve that lies horizontal facing towards the front of the tractor. Between the bypass and hold valve.
