David Brown info...
Steve (Magnolia
05-08-2003 14:09:46
First off, I'm visiting from the Ford 'N board, so please excuse my David Brown ignorance.
I've become known as "the tractor guy", at work, and a friend of mine has his eye on a David Brown that he's seen for sale and he asked me to take a look and give him my opinion.
Some starter questions (I have yet to even see the tractor).
1. Assuming the decals are missing/worn/faded, is there a data plate where model and serial numbers are stamped? Where would I find it?
2. Approximately how many different models of David Browns were made?
3. When were they made (I realize that Case bought them out, when?)?
4. Are there any specific 'trouble' spots that I should look for?
Thanks,
Steve
Woodbeef
05-09-2003 15:44:13
 Re: David Brown info... in reply to Steve (Magnolia, TX), 05-08-2003 14:09:46
Most of the few that I've seen are actually 996s,but badged as 995. The 996 has the independant pto like the bigger ones. If it does have the independant pto,check and see if the hand clutch has been left engaged,but that the pto selector is in the off position. Also if the rubber boots are shot on the shifters it will leak water and wreak havoc on the hydraulic system. All in all a very good tractor that is often underated!!
05-09-2003 06:57:31
What would be a fair price for a good condition 995 (assuming that everything works, and it runs well)? Tires at about 25% remaining tread.
James
05-09-2003 08:38:06
 Re: Re: David Brown info... in reply to Steve (Magnolia, TX), 05-09-2003 06:57:31
I bought one in 'fair' condition, needing tires and some other work, runs good for $800. There is one here in the Kansas City paper for $4000-4500. That is probably about right. You can't get tires cheaper than $600 for the pair in back.
James
05-08-2003 16:23:45
1. Right front of frame on top.
2.1961: 880 40hp, 990 52hp, 1967: 780 36 hp, 880, 990, 1200 65hp 1971: 780, 880, 885 42hp, 1210 65hp, 1212 65hp, 1972: add 995 58hp 1975: add 1410 80hp, 1412 80 hp
3. Case 1980-1989
4. If the hyd. trans. fluid is dirty the 3pt. will not work.
05-09-2003 06:39:51
 Re: Re: David Brown info... in reply to James, 05-08-2003 16:23:45
Perfect! Thanks...
BTW... I stopped and looked last night.
It's a 995 and it does have the Case name on the decals on the hood.
The tractor appears to be in good shape (no obvious oil leaks or welds, etc. visible from ~10', it was inside a fence), other than the tires. All 4 are at about 25%.
Mike Johnston
05-08-2003 14:50:03
Steve,
Most of your questions can be found at the page linked below.
I'm just down the road from you on the north side of Houston.
Mike
Dr Cy Kosis
05-09-2003 19:15:11
 Re: Re: David Brown info... in reply to Mike Johnston, 05-08-2003 14:50:03
Mike J,
Hows the old ThunderChicken?
Mike Johnston
05-09-2003 20:29:17
 Re: Re: Re: David Brown info... in reply to Dr Cy Kosis, 05-09-2003 19:15:11
You been talking to a Haggard? :-)
Mike Johnston
05-09-2003 19:22:17
I refuse to answer that until I know just who the heck is asking??? :-)
Dr Cy Kosis
05-10-2003 06:31:44
 Re: Re: Re: Re: David Brown info... in reply to Mike Johnston, 05-09-2003 19:22:17
Hmmmmm ..... ...sounds like I struck a nerve there, don't it?
05-09-2003 06:41:02
Excellent!
I'll take a look. Look at my response to James, for further details on the tractor...
