HELP: Rearend oil level for SC?
Richard
05-07-2003 21:29:31
Where should the oil level be in the rear end? I see the BIG plug that is under the seat but were should the oil level at? At the bottom of that plug or at the bottom of the PTO Plug? IT shop manual said that the cap is 38-42 qts plus 10 qts for the PTO. Do the two share? I think that the BIG plug is to add.
Thanks in Advance
Richard
C. Amick
05-08-2003 08:46:18
 Re: HELP: Rearend oil level for SC? in reply to Richard, 05-07-2003 21:29:31
Both the plugs that are on top at the left side just under the seat are fill plugs. One for the transmission and one for the PTO. They do not share. The level plug for the PTO is just below and to the left of the PTO shaft. I think the level plug for the transmission is on the right side of the tractor closer to the front but behind the axle and down low? Having trouble picturing exactly where this one is.
