ID info and Loader Quit Working
Kevin
05-06-2003 18:04:38
I bought a case tractor a few months ago. The tag on the steering cowl indicates it is a G530B, the serial number is 8274978. I found two other ID tags on it, one on the left side frame near rear wheel 'Model 32 NO. 4078498' and the other tag on the engine near the oil filter 'NO. 2024979'. It has 'Construction King' emblems on it. I think it is a 1966, but not sure. It has a gas engine. Based on this information, can some one confirm the year and tell me what size the engine is?
When I bought it, the loader worked fine. A couple months later, it started to not work so well. It would not go up all the way. After a while it wouldn't go up at all unless it was facing down hill and it would only go up about 3 feet. Now it won't work at all. I checked the filter, it looked fine. The fluid level is fine. Did the pump go? if so, is it hard to replace and what does a new or rebuilt pump go for.
Thank you,
Kevin.
