Hydrolic cylinders
mike
05-06-2003 11:05:42
took apart one of my stabalizer cylinders to change packing and i am haveing trouble getting the nut off on end of piston,are these things loctited on?it's off of a case 680e. thanks mike
Redd
05-06-2003 19:59:08
 Re: hydrolic cylinders in reply to mike, 05-06-2003 11:05:42
Mike , most of those nuts should come off w a 3/4 inch impact gun. You dont want to hammer on them forever but if you have to , put an acetylene torch to the nut (only) , heating it rapidly then again w the impact. Make sure You use loctite when putting it back on.
Illini Case
05-06-2003 19:26:05
Yes, Locktite---must be heated above 250 degrees to break the bond.
