Trans. oil guestion
scott
05-04-2003 19:27:27
What would be the disadvantage of using 80-90 weight oil in the transmission on a 700 series case. I know that there is some wear in it. Just wanted to get someone eles opinion on this. Thanks again in advance Scott
John Saeli
05-05-2003 16:02:03
 Re: trans. oil guestion in reply to scott , 05-04-2003 19:27:27
Scott; You asked about the correct oil in the transmission. If the trans. resovoir is separate from the hyd. resovoir then by all means, use an 85w-140 gear oil in the trans. If the hyd and trans are one common sump, you will need to use a transmission-hyd. fluid..To add body to that thin fluid, add 1 quart of 85w-140 to 3 quarts of trans.-hyd. fluid. I've done it for years and feel that it has added life to my CASE transmissions. Hope this helps, John
Tom
05-05-2003 06:37:37
Must use the correct oil as stated in the manuals for your particular tractor model. Many tractors have a single sump for the trasmission, differentil, 3 pt hydrolics, remote hydrolics, PTO hydrolics, wet brakes, final planatary drives, and other things. The base oil and the additive packages included keep all these things working. Use the wrong fluid and you can be looking at big, expensive trouble. Get the Manuals and follow them.
DKase
05-05-2003 05:55:23
Does the tractor have one shifter or two? If it has a second shifter for the high/low range the trans. oil is the hyd. oil. If it has the old style single shift lever the hyd. oil is seperate from the trans. oil. You would not want to use 80-90 in the hyd. system. Good Luck
