Will a VAC be a good choice ?
JimmyG
05-04-2003 17:21:19
I am interested in getting a tractor to scrape my drive way in the winter. I have been using a Case 57 400 diesel and am wondering if a VAC is heavy enough to replace this machine at snow removal. Do the Eagle hitch lifts on VAC's have down pressure for dragging dirt around? If not a VAC what is a good choice?
mj
05-04-2003 19:33:47
 Re: Will a VAC be a good choice ? in reply to JimmyG, 05-04-2003 17:21:19
I use a 7' Howse blade behind my VAC and it moves snow like no tomorrow. It also cuts dirt well as the blade is fairly heavy. I'm running a single wheel weight on each side with no liquid in the tires. When I'm plowing heavy snow on ice I hang a set of chains....works great.The Eagle hitch does not have down pressure but I had a tractor with it once...as soon as you start putting pressure on a blade or ripper the tires start to spin....worked great for drilling post holes, though. Adding weight to the implement and/or changing the angle of the cutting edge willl get you more than hitch down pressure. :-)
Ross
05-13-2003 20:28:20
 Re: Re: Will a VAC be a good choice ? in reply to mj, 05-04-2003 19:33:47
mj I don't mean to disagree with you. I have a VA with a homemade three point and you are right. It does a good job pushing snow and dirt. According to my shop manual for the VA series there was a two way option for the VA's with the live hydraullics.
Ross
