Transmission oil
scott roland
05-03-2003 19:26:41
Can anyone tell me what type of oil was used in the transmission on a 700 series case. Thanks in advance Scott
DKase
05-03-2003 21:30:00
 Re: transmission oil in reply to scott roland, 05-03-2003 19:26:41
Any good quality hyd. oil will work OK. Most Case guys run the Case/IH Hy Tran. It is a 10 wt. oil. I prefer the JD hyd. oil because it is a 20 wt. It doesn't get as thin in hot weather but it does not get so thick in the cold weather. I assume since you requested for a 700 that you do not have a case-o-matic. That takes ATF oil.
Slowpoke
05-03-2003 23:00:25
 Re: Re: transmission oil in reply to DKase, 05-03-2003 21:30:00
What kind of ATF? I just bought 10 gal of Citgo Hydraulic Fluid Red that meets Case Spec. 1203. It's supposed to be correct for my Case 800B Case0Matic.
Is it actually ATF of some kind?
