Caseman-d, I checked on the SC front hubs.
jal-SD
05-02-2003 06:15:30
They are both there, look the same & appear to be OK. There is also a pair of pressed steel wheels, the rest of our SC's have cast wheels. Didn't take them apart. Where are you located in our great state? I'm @ Mitchell, & the parts are less than 2 miles from Cabela's new store, if you get over this way to shop at it, give me a call & we can go look @'em. I can e-mail you phone #'s if you want. (My $0.02 worth. jal-SD)
caseman-d
05-03-2003 13:19:09
 Re: Caseman-d, I checked on the SC front hubs. in reply to jal-SD, 05-02-2003 06:15:30
jal-SD,
I looked at another 44 SC and and the hubs were the same as the ones I have, was looking for set with the bigger bearings, since they have that dust sheild I'm not sure how to tell the difference.
I had a couple of bearing places cross the Case numbers and they disagreed on which bearing and races I needed to work. I will check the Case numbers again Monday when I go to work.
Thanks for looking. I live in the big little biker town in the western part of the state. Might be going past your way in Sept. caseman-d
