Db 990 lift
steve
05-01-2003 10:27:07
do anibody have some drawings of the oilpump
system lift dont work but i can hear the pump running
sorry for my englisch i am from belgium
tractor still works every day on the farm
greets steve
Elmer
05-01-2003 17:11:03
 Re: db 990 lift in reply to steve, 05-01-2003 10:27:07
There are two spool valves in the control valve that can stick. If you have a fax number i can fax a page from the manual to you.
steve
05-02-2003 03:14:56
 Re: Re: db 990 lift in reply to Elmer, 05-01-2003 17:11:03
sorry no fax
you can mail it to me
[email protected]
greets steve
Elmer
05-03-2003 16:54:47
 Re: Re: Re: db 990 lift in reply to steve, 05-02-2003 03:14:56
My scanner is no good. Can you find a fax?
James
05-01-2003 14:40:45
Do a search here. Use words like 'David Brown', '3 point', '3pt', and 'control valve'. You will see responses to many people having the same problems in the past. (The easiest way to find posts relating to David Brown tractors on this site is to search for "Elmer" He is the expert and answers nearly every DB question.)
Make sure your hydraulic transmission fluid is clean, the filter is changed, and then be sure the spool valves are not stuck or plugged up.
steve
05-03-2003 03:21:43
 Re: Re: db 990 lift in reply to James, 05-01-2003 14:40:45
where do i find the spool valves
hydraulic transmission fluid ok
filter ok
greets steve
Bernard le m�cano
05-09-2003 18:56:33
 Re: Re: Re: db 990 lift in reply to steve, 05-03-2003 03:21:43
Hi Steeve, the valve is in the rear axle housing, on the right side. On the top of the housing, it's a cover with two screw, that is access for valve spool. If you want pic of the valve, i can scan and Email you. Bernard le m�cano Qu�bec Canada
