Fuel filter needed!
Kelly
04-30-2003 22:47:23
My Case 500 diesel needs a primary fuel filter element replaced. It's a brass fine mesh type. Purelator I think. It's clogged up with fine particals and I can't get it clear. Any Ideas? Thanks PK.
Slowpoke
05-01-2003 23:53:17
 Re: Fuel filter needed! in reply to Kelly, 04-30-2003 22:47:23
Try soaking in dish or laundry soap and hot water. Strong spray cleaner might help,too. Not much will hurt a bronze filter.
caseman-d
05-01-2003 20:08:52
You should be able to replace it with a canaster type fuel filter. I replaced mine with a spin on filter housing and filter. Main thing is becarefull on getting a to fine a filter to cause restriction.
caseman-d
John Saeli
05-01-2003 15:56:59
Kelly, Can that filter be washed with gas and blown clean with compressed air?
Kelly
05-02-2003 22:23:53
 Re: Re: Fuel filter needed! in reply to John Saeli, 05-01-2003 15:56:59
It's hard to use air as the fuel flows from the outside in. My service manual says not to blow in so as not to lodge the dirt. The filter looks clean but it starves the engine for fuel. It runs like a champ with the element removed. When I blow air inside out my blow gun seals the element at the threads and builde up quite a lot of pressure. May try that soap and hot water idea before I give up and put a spin on filter on it. Thanks for the help PK.
