SC engine parts
Ron Cook, (IA)
04-30-2003 09:05:06
I have located an SC that has a bad engine. Is there any source of engine repair parts, bearings, pistons, rings, sleeves, etc. All I have found is heads and crankshafts. This is otherwise a pretty fair example of an SC but engine parts availability will affect the price, I suppose.
C. Amick
04-30-2003 10:49:35
 Re: SC engine parts in reply to Ron Cook, (IA), 04-30-2003 09:05:06
New piston and sleeve sets are available for around $900. Main bearings are no longer made, but you can buy reconditioned ones at around $200 a set. Rod bearings are no longer made either, but there are still some in warehouses. They are about $50 each. I wouldn't replace the pistons unless they are damaged or the sleeves are worn too much. If I haven't scared you so far, then call Don at 507-433-0073.
Ron Cook, IA
04-30-2003 21:47:20
 Re: Re: SC engine parts in reply to C. Amick, 04-30-2003 10:49:35
That's the sort of information I was needing. It is scary, but I thank you. Now I have some info to help me come up with an offer.
