Hydraulic problem
Mary
04-30-2003 07:33:54
Looking for some info,on a 1070 case tractor. The hydraulic control valve won't lift. Any ideas on this?
Shane
04-30-2003 09:46:24
 Re: hydraulic problem in reply to Mary, 04-30-2003 07:33:54
We had one do this last year, it ended up being the valve body under the fuel tank that has the arms the levers are connected to. Take off is pretty easy and it just needed new o-rings. Make sure the pump is working properly too, had one of those get weak once and caused the steering and brakes and hydraulics to act funny.
Mary
04-30-2003 10:33:10
 Re: Re: hydraulic problem in reply to Shane, 04-30-2003 09:46:24
Thanks for the infomation. I will get back with you on how we did. Again, thank you, that was a quick response.
