SC Steers Hard
Crispin
04-28-2003 10:53:05
'52 SC steers real hard. Took off the long link going forward and no better. Gave it greese too. Any suggestions? Thanks
C. Amick
04-29-2003 09:23:19
 Re: SC Steers Hard in reply to Crispin, 04-28-2003 10:53:05
If you put 90 wt. gear oil in the housing, I wouldn't fill it. You probably only want to put in a cup or so of oil. After I put the oil in it, there was water that dripped out the bottom. At least the oil somehow forced some of the water out of it.
laipuller
04-29-2003 06:48:09
wheaties works...LOL... does it have cast wheels, if so get a set of pressed steel for it.
klyde
04-28-2003 21:30:03
how much play is there in the steering wheel? did sombody tighten the adjuster bolt too tight? its the one on the side of the transmission cover with a jam nut on it. that bolt on the front is for the truss rods when you put culitavators on.
Mike Schotte
04-28-2003 18:47:17
Hi Crispin,
Myron was telling me the other day that he removed that hex head bolt on the side of the gooseneck casting and filled it with 90W oil.
That's NOT a lubrication point according to the Operator's Manual- but a look at the parts manual would lead you to believe that it just covers a void between the upper and lower pivot bushings in the front end assembly.
Sounds like a good idea to me- and Myron said that doing this really eased up his steering.
(I always wondered what that dang bolt was for...)
-Schotte
Les...fortunate
04-28-2003 16:57:01
Gotta be some place that ain't gettin the grease or is bound up for some reason.
Ralph
05-01-2003 17:49:15
 Re: Re: SC Steers Hard in reply to Les...fortunate, 04-28-2003 16:57:01
Maybe there's a duck stuck in it
