VAC exhaust manifold
Lew
04-27-2003 19:53:41
Is the elbow coming off the exhaust manifold on a VAC attached with cap screws into the manifold or with nuts on studs coming out of the manifold? Mine is so rusty I can't tell. Thanks to any who responds.
C. Amick
04-28-2003 09:44:35
 Re: VAC exhaust manifold in reply to Lew, 04-27-2003 19:53:41
To remove one of those bolts, heat the manifold until it gets cherry red at the bolt. Tap the bolt with a hammer and twist on it with a pair of vice grips. You should be able to get most of them out this way. You may end up drilling a few of them out.
CASEPOWER
04-27-2003 20:33:31
3/8 x 1" cap screws.They also used a lock washer when new.
Lew
04-27-2003 21:24:51
 Re: Re: VAC exhaust manifold in reply to CASEPOWER, 04-27-2003 20:33:31
Thanks for your prompt reply.
