Oil pan removal on 210B
Mike Johnston
04-27-2003 11:31:04
This utility tractor has a non-adjustable front axle. The service manual seems to indicate that the oil pan can be removed without dropping the front pivot bracket or axle, just the radius arm needs to be removed. I sure don't see how the pan could come off without dropping the bracket and axle. Am I missing something?
The old thing has no oil pressure at all. Need to get in there and find out why.
Mike Johnston
Jim M
04-28-2003 09:53:16
 Re: oil pan removal on 210B in reply to Mike Johnston, 04-27-2003 11:31:04
I'm not sure but I think you will have to drop the axle and support and reach in and lift up the floating suction screen so the pan will come off. The oil pumps have a problem shearing a wooddruf key inside it where the internal gear attaches to the shaft. I've try to check mine often to catch it early and replace the key before any damage is done. Case says they are not serviceable.
Mike Johnston
04-28-2003 11:35:27
 Re: Re: oil pan removal on 210B in reply to Jim M, 04-28-2003 09:53:16
Jim,
Thanks for the response.
I did have to pull the axle and pivot bracket to get the pan off. The pick-up screen was broke off. Had been welded back on years ago, but did not hold apparently. It looks like it still would have made pressure if the oil was higher than the break, but if the oil level was too low the pump was just sucking air. The tractor had plenty of oil according to the stick, but it still could have been lower than the break, I guess.
I'll look at the key before re-assembling.
Thanks again,
Mike Johnston
Mike Johnston
04-28-2003 12:41:05
 Re: Re: Re: oil pan removal on 210B in reply to Mike Johnston, 04-28-2003 11:35:27
Well, it looks like the pressure problem is solved. The relief valve was stuck open. I don't have a clue how that could happen. After removing the retainer cap and spring and freeing up the valve, the pump will now pick up oil out of a pan while spinning the gear by hand. It would not pick up oil at all earlier. Finding the broken screen tube looks to just be a bonus. Upon looking closer, it is apparent that the oil level was above the break. But with the valve open, no oil was being moved.
