Ser.# location on a...
Dan
04-26-2003 22:19:32
Case C. Is it stamped some place like on the DC4? Thanks.
Brian in Ohio
04-27-2003 04:09:14
 Re: Ser.# location on a... in reply to Dan, 04-26-2003 22:19:32
Not sure where the SN is stamped on a DC4, but on a "C", it is stamped on the mag side of the engine. If you are looking at the mag, look to the far left side, next to the gas tank. Right where the block and head come together, there should be a machined flat surface with the serial number stamped.
CASEPOWER
04-27-2003 13:57:36
 Re: Re: Ser.# location on a... in reply to Brian in Ohio, 04-27-2003 04:09:14
The serial # on the D series is put verticaly on the flange that bolts to the bell housing on the left side. The C series is on the right on a oprox. 1"x1-1/2" machined flat spot. The D series has the flat spot there but no #s on it. Can't figure out why they changed and would love to hear the engineers reason..
Dan
04-27-2003 08:37:48
Thanks Brian.
Bob
04-27-2003 14:23:35
 Re: Re: Re: Ser.# location on a... in reply to Dan, 04-27-2003 08:37:48
Should also be posted on a tag on the toolbox
