DC overheating
awhitaker
04-23-2003 16:56:50
I have a 52 DC-3 that has a new radiator and a rebuilt water pump. If the tractor is worked very hard, the temp rises to about 220 degrees according to the temp gauge. Steam comes from under the radiator cap. Why would this tractor overheat? Should I do a radiator flush and see if that'll get the build-up out of the water jacket? Any ideas? thanks
John Shivers
04-29-2003 18:37:48
 Re: DC overheating in reply to awhitaker, 04-23-2003 16:56:50
Had similar problem. DC system does not force water down through radiator. ANY scale, etc will easily plug coolant tubes. If block was not flushed before installing radiator, even new tubes could be plugged. Look in radiator with engine running. If you do not see water circulating, tubes are plugged. You can rod out a few from the top. To do it right you must pull radiator, remove bottom tank and rod each tube. There are about 100 of them!. I put a large magnet in my radiator to catch the scale as it comes by. helps a little.
Jim M
04-25-2003 18:53:43
I bought a 500B once that had gotten so hot it spun 2 rod bearings and warped the block. I found that someone had put the fan on backwards and was not cupping the air it spun. Check the fan so it cups the air
Flambeau Red
04-24-2003 15:34:25
Check to see if you have shutters on the front of your radiator. We had the an overheating problem on our DC and discovered that we couldn't keep the shutters open so we took them out.
Dale in TX.
04-23-2003 21:37:01
Try new fan belt as the belt is tightened the fan slows down, DC was marginal in cooling anyway,so need to keep RPMs up on fan. Good luck Dale in TX.
Craig
04-24-2003 11:25:03
 Re: Re: DC overheating in reply to Dale in TX., 04-23-2003 21:37:01
I just rebuilt the engine on my 1953 DC & found a ton of rust scale around the piston sleeves. With the tractor having a cast block, it tends to rust inside. Just an idea but you may have a bunch of rust inside the engine which is reducing the cooling effectiveness of the coolant. my 2 cents worth!
