Manifold heater Case 1070
Bud
04-23-2003 04:49:42
I have a heater installed in the intake manifold on my 1070. My question is how long do I hold the keyswitch in the heat position before cranking? Also How does that thing work inside the manifold? I could not feel it getting warm around the area that it is screwed into. Not a big deal but just mainly curious. Thanks!
Bud
RoyG
04-23-2003 18:03:17
 Re: Manifold heater Case 1070 in reply to Bud, 04-23-2003 04:49:42
Should hold key for 30secs. Best thing to do is remove the heater and see how far you can throw it. I have seen several engines ruined because somone either held the key to long or it did not shut off and burned up the coil in the heater and those parts on top of a piston ain't good.
A 1070 in poor shape will start if the batterys are good
MGM
04-23-2003 04:58:32
My manual says to hold the key full left for 30 seconds, this heater is a good way to help atomize fuel when cold to help combustion. Mike
The new car and truck manufacturers are going back to the old heater now instead of glow plugs, found out it worked pretty good
