Farming with CC steering
Okla/Kans Bill
04-22-2003 19:41:52
iffn theres anybody still farming with a CC, do you notice one side turns shorter and easier than the other? When I turn right, it turns easier than when I turn left. Also, im positive the gear teeth are jumping somwhat as somtimes it seems like I can turn shorter left than right, and then sometimes the other way around. Whichever it is, when the side that is not turning all the way does that, I can stand on the brake and it wont hardly faze it. Anybody notice anything like that.
CASEPOWER
04-22-2003 20:48:20
 Re: Farming with CC steering in reply to Okla/Kans Bill, 04-22-2003 19:41:52
When you turn the steering wheel back and forth how far does the steering shaft raise were the steering wheel bolts on?? Does the steering wheel feel loose on the shaft?? The steering system is simple on a CC. There are two thrust washers one on the bottom and one under the steering wheel. When you tighten the steering wheel it takes the up and down movement out of the shaft. If it turns harder one way then you could have one thrust washer bad because when you turn left it puts the pressure on the bottom washer and when you turn right it pulls down on the steering wheel and puts pressure on the upper thrust washer. I replaced my thrust washers with thrust bearings out of a borg warner T-5 transmission with .020 stainless washers on each side. It makes it steer much easier. I just can't see one jumping a gear, but I would have the tranny top off and be finding the problem as soon as possible. If anything breaks loose theres some big teeth on them tranny gears to grab it up..
okla/Kans Bill
04-23-2003 18:33:54
 Re: Re: Farming with CC steering in reply to CASEPOWER, 04-22-2003 20:48:20
If your talking about up and down movement on the steering post, thereaint any that I ever noticed, or at least worth remembering, but there is end play in the arm that comes out of the steering gear and attaches to the arm runnng down to the front end of the tractor, and theres a bit of play in the steering between when you start turning the wheel and when the post outside the steering sector feels any movement. Not quite a quarter turn
