David Brown PTO
Paul White
04-22-2003 17:15:54
I have a David Brown 950 and the clutch does not disengage the pto. I have to shut off the tractor , engage the lever and then start the tractor with the pto engaged. The clutch pedal has a bracket with two holes for a lever to attach to but I do not know where this would go? Could there be an external linkage for Pto or is it in the trans? Any ideas would be appreciated. Thanks Paul
Ritchie Leslie
04-24-2003 10:20:06
 Re: David Brown PTO in reply to Paul White, 04-22-2003 17:15:54
The 990 has a protruding bolt on the clutch pedal to operate the PTO clutch. Maybe the 950 is the same? This bolt, which operates when the clutch pedal is fully depressed, in turn engages with another cam which turns a horizontal rod that enters the side of the transmission housing. If all this is absent could be your problem.
Also the clutch is two stage and mine was seized on stage 2 when I bought my tractor. Like yours I couldn't operate the PTO lever when the engine was running. Took off an inspection port, levered the clutch plates apart and everything was OK.
If you have a friendly CASE dealer they might help if they service DB tractors. You could also try the David Brown Tractor club in Huddersfield, Yorkshire for help and advice. Link
