My 1967 CASE lawn tractor needs a new motor
James R. Moyer
04-22-2003 17:14:21
My 1967 Case lawn and garden tractor 155 needs a new motor. I emailed Kohler and Briggs&Stratton about my tractor but have no response as of yet. My question is, if they cant help me is my old tractor done for?
Right now it has a Kohler 14hp model k321a spec#60272 motor. Im just looking for a new up to date motor to fit my old drive train.
Max
04-23-2003 11:24:03
 Re: My 1967 CASE lawn tractor needs a new motor in reply to James R. Moyer, 04-22-2003 17:14:21
Those were special short blocks made for Case. They had a special bolt pattern for the hydraulic mount and I beleive that the flywheel was special for the Case version. Once while at a Case Dealership we tried to save a few bucks and get a short block from a local Koehler distributor, that's when the differences were discovered.
As far as making another engine work, it would be possible but some adapter plates and machining may be required.
James
04-24-2003 16:04:00
 Re: Re: My 1967 CASE lawn tractor needs a new motor in reply to Max, 04-23-2003 11:24:03
Briggs&Stratton finally replied to my email. They said that one of thier service dealers could come out and take a look at my tractor. If any special
modification can be made they would let me know. So
its quit possible one of thier motors could work.
Ill post another reply if anything pans out. Kohler
still hasnt replied. I thought they would really be the first ones to help me.
James Moyer
John H-WI
04-22-2003 18:30:44
A repair service near me advertised about switching old single cylinder engines to the twin Briggs & Stratton Vangard. Might be worth looking into.
RayP(MI)
04-23-2003 07:57:17
 Re: Re: My 1967 CASE lawn tractor needs a new motor in reply to John H-WI, 04-22-2003 18:30:44
Did that to my JD 140 garden tractor a few years back. Worked out very well. E-mail me if you want a print out of the step-by-step description of my project. Part numbers included!
AllanC
04-25-2003 20:56:38
 Re: Re: Re: My 1967 CASE lawn tractor needs a new motor in reply to RayP(MI), 04-23-2003 07:57:17
I would rebuild the Kohler. It can be expensive but I think it would be cheaper and less fuss than putting something else in. If the cylinder and rings are worn it can be rebored but check the carburettor shaft. If it is worn you must fix it. It's amazing how much dirt they'll suck in there.
James
04-24-2003 16:07:31
Please read my followup to Max's post.
Thanks for the input!
James Moyer
Roger
04-24-2003 23:18:57
 Re: Re: Re: Re: My 1967 CASE lawn tractor needs a new motor in reply to James, 04-24-2003 16:07:31
I'll take a Kohler over a Briggs & Scrapiron ANYDAY. Why dont you rebuild the original engine Jim ? ..... ..... ...Roger
