Converting LPG 930 to gasoline need advice please help!!
R Wyler
04-19-2003 12:51:56
I am wantibng to change my lp 930 over to gasoline will the engine with it's current state run on gasoline if I install a carburetor? And also will a regular carb fit the existing manifold? Thanks for any help.
scottAR
04-20-2003 19:03:39
 Re: Converting LPG 930 to gasoline need advice please help!! in reply to R Wyler, 04-19-2003 12:51:56
Please don't mess up a good tractor by converting it to our sorry gasoline.
R Wyler
04-21-2003 04:47:39
 Re: Re: Converting LPG 930 to gasoline need advice please help!! in reply to scottAR, 04-20-2003 19:03:39
You are right I decided to leave it on lpg. Thanks for the post. Richard.
Kennyp
04-20-2003 07:44:19
If you were here in Co at 5000 ft elevation it would probably be OK. Slow the timing back to prevent spark knock. (very distructive).
R Wyler
04-20-2003 12:51:16
 Re: Re: Converting LPG 930 to gasoline need advice please help!! in reply to Kennyp, 04-20-2003 07:44:19
Thanks for the tip. Richard.
jw
04-20-2003 07:36:43
I wouldn't do it, I've been looking for one for a while and they're not that easy to find, besides lp burns alot cleaner. I'm not sure but to make it run right you may need different heads but it will probably run okay leaving everything and switching carbs.
R Wyler
04-20-2003 12:52:52
 Re: Re: Converting LPG 930 to gasoline need advice please help!! in reply to jw, 04-20-2003 07:36:43
I would think that it would. Did they use different heads? Thanks for the help. Richard.
