Doug Weicht
04-19-2003 03:33:02
Hi
I was hoping that someone could clear this problem up for me. I have heard so many differnt ways to figure out the year on the old gray case tractors that now, I am not really sure what year my Case C is. Would someone please tell me how to figure out the year for tractors like this. Thanks
Doug
Brian un Ohio
04-19-2003 19:13:07
 Re: Serial Numbers in reply to Doug Weicht, 04-19-2003 03:33:02
for you "C", you serial number should consist of the letter C plus a 6 digit number. Take the first and fourth digit, put them together, and subtract 3 frm that number.
Example: C300916 3=first digit 9=fourth digit... 39 - 3 = 36. This serial number is from a 1936 model "C".
Hope this helps!
Bob
04-21-2003 14:30:29
 Re: Re: Serial Numbers in reply to Brian un Ohio, 04-19-2003 19:13:07
This works for the 6 digit serial numbers.
From 1938, 7 digit numbers were used. The rule there is take the first 2 digits and subtract 4.
To confuse the issue, there are some 7 digit numbers serial numbers on 1936 and 1937 built tractors � my C is one of these (C3109577). If the serial number is 7 digits but the first 2 digits are less than 42, use the 6 digit rule.
Doug Weicht
04-20-2003 04:07:05
Hi
Thanks Brian, it is alot of help.
