TSX114 float repair/replacement
Ted in Sacramen
04-18-2003 10:25:36
If it's not one thing it's the float, one half of the float is filling with gas, causing the carb to pour out gas, this after it ran sucessfully last weekend. Found the leak, how do I insure that if I solder I won't be igniting a small gas bomb. Would I be better off replacing if I can get this part (it is collapsed in the back on the damaged side), can I get a new float?
mj
04-18-2003 17:29:46
 Re: TSX114 float repair/replacement in reply to Ted in Sacramento, 04-18-2003 10:25:36
It won't 'blow up' if you use a soldering gun or electric soldering iron...if you use a torch you're on your own. There is a small hole that's soldered shut on most floats (drill one if necessary); de-solder this hole and shake the gas out, make your repairs and let the float cool then re-solder the vent hole. Do this quickly to prevent the air inside the hole from heating up or when it cools down it can suck the solder you just used on the vent hole back into the float.
Ted in Sacramento
04-18-2003 16:40:06
I withdraw question about soldering float unfair liability wise and I've seen that concern here and respect it. Did get a repair done but only time will tell if it works. Next time it comes off it gets a new float and a hex head screw for the choke cable, currently slotted and on the engine side, what a pain.
Slowpoke
04-19-2003 00:31:41
 Re: Re: TSX114 float repair/replacement in reply to Ted in Sacramento, 04-18-2003 16:40:06
The choke cable is a pain to get loose to remove the carb. It's been a while since I modified mine, but I seem to remember tack welding a square nut on the cable clip and putting in a screw from the front side. The screw was the next size down, so if it didn't work out, I could grind off the nut and return to the original screw from the back. Maybe JB Weld would work in place of welding the nut. I also put in a steel gas line and used tapered shoulder inverted flare nuts and a right angle inverted flare fitting at the carb and gas filter outlet. I think the original line was on the outside of the carb; I bought the new line in at the back. It looks much better than the old compression fittings and the line on the outside where it was subject to damage.
Mike from Canada
04-18-2003 15:04:48
i had a friend that found a temporary solution by draining the float, and then coating it w/ nail polish. seemed to work for a few years until he got tired of patching it and bought a new float.
floats are available aftermarket. just get the ser# off the back of the casting (where it mates to the manifold) and they shouldnt give you a problem.
mike
mike b.
04-19-2003 03:58:12
 Re: Re: TSX114 float repair/replacement in reply to Mike from Canada, 04-18-2003 15:04:48
Ted,just a word of caution.I had a float start to leak after using gasahol in my 49 Stude.truck.Apparently the alchohol deteriorates the solder in some older carburetors.I had to repair mine twice before a carb. expert told me this.Good luck,Mike B.
