LA piston to cylinder head combinations
Thad
04-17-2003 18:41:16
I have a LA with the 1/8 overbore. I have a lp head i was going to install on it. We removed the head that was on the tractor to find out that the pistons stick out above the deck. So that wont allow me to install the lp head. What it had on it for a head was the very low comp head. What are the other 2 heads like? Can i use another # head still use these pistons and get the comp up. Thanks Thad
someone
04-20-2003 20:20:37
 Re: LA piston to cylinder head combinations in reply to Thad, 04-17-2003 18:41:16
You copycat.
RobertTX
04-18-2003 05:46:48
I have heard that the LP head with the standard pistons is the most common combination people are using. If you go piston shopping though, remember that there is also a low compression piston for the older dual fuels that has TDC below the deck. If you don't have a patrs book, you might want to invest in one and use it as a guide. The guys at Case used the same number for parts number and casting number, so you can just pick up almost any part and read the part number off it.
CASEPOWER
04-17-2003 20:13:00
The Gas and LP head will have the bathtub chamber and was not intended to run the high altitude pistons. Depending on what your plans are for the tractor as to what to do. If you are planning to pull it and want high comp. take the pistons out and mill the tops flat or about .020 above the deck. then put the LP head on. If you use the tractor just take about .100 off the low comp head and stick it back on. All of the Case heads shroud the valves to much so if I went with the LP head I would grind a little out around the valves so the chamber sides don't shroud the valve so much and hurt the flow. Just be carefull and don't take to much away.
Steve-IA
04-18-2003 04:29:29
 Re: Re: LA piston to cylinder head combinations in reply to CASEPOWER, 04-17-2003 20:13:00
Hi Casepower,
My LA build sheet('49) I just got lists 'H.C. Pistons' under Head Type. I've never had the head off. I'm assuming this meant High Compression. How much more is it? Is just the piston different or is the head different too?
Thanks,
Steve Moeller
CASEPOWER
04-18-2003 17:57:35
 Re: Re: Re: LA piston to cylinder head combinations in reply to Steve-IA, 04-18-2003 04:29:29
I would think that you have the High compression pistons and the low comp. head. That was a way of changing a low cost fuel engine into a gas engine by a simple piston change instead of changing the head. The D series didn't use the 5505 untill the early 50s on the tractor, but used it on power units much ealier. Case would just use the HC pistons with the low comp. head. I had to take .040 off of the HC pistons to run a gas head. and they still come above the deck, but the head gasket thickness makes up for the difference. I took .020 off first and it was fine when running cold but when it got to operating temp the heat expantion made the pistons tap the head. I had checked it with play dough on a mock build of the engine but did not figure in for the change when it heated up. You gotta learn some things the hard way..
Steve-IA
04-20-2003 15:04:45
 Re: Re: Re: Re: LA piston to cylinder head combinations in reply to CASEPOWER, 04-18-2003 17:57:35
Thanks for the great info Casepower!
Later,
Steve
Steve-IA
04-20-2003 15:04:37
Later,
Steve
Thad
04-18-2003 04:08:49
Im going to use it for pulling. I was wondering if they had a head similar to the 5576 on the dc. The popup piston will fit on them but i havent seen the chambers on all the la heads to know. The problem i see with milling the pistons is i dont want to ruin a piston. I dont have any spares and the comp might be to high. That lp head has a very small chamber. Have you heard of anyone that has had flat pistons in one with the lp head and had it hold up ok? Thanks Thad
CASEPOWER
04-18-2003 17:49:30
 Re: Re: Re: LA piston to cylinder head combinations in reply to Thad, 04-18-2003 04:08:49
Thats were you have to do some research before you jump in head first. CC your LP head. You can do this by setting it up level with the valves in it and the spark plug in. Then take a piece of plexiglass and drill a 1/8" hole in it and place it over one chamber. Use a suringe and fill it up with water keeping track of the CCs you use. ML on the suringe is the same as CCs. Then take your bore, stroke, head gasket thickness, head gasket bore, and figure your CCs with the piston at deck height. Then you can figure it above deck height and below. It is no problem to tell how much compression you will have before you ever start. If you just post your head CCs of your LP head and if your at stock bore and stroke I will be glad to figure your compression. Also let me know the head gasket bore because they are usually bigger then the piston bore. If your using a stock gasket I know the thickness. I was never intending on trying to get you to jump into just throwing something together. Also if you will check the CCs on your old head and send me the info I will tell you how much compression you were running with it so you will know what kind of gain you will be getting from the change. Just let me know if I can help..
Kennyp
04-18-2003 07:21:25
Not me, but a farmer friend.... Can't tell you what pistons, but he told me he used the LP heads and proceeded to tear the main bearing loose. So he stripped out all the parts and used a different block to put them all back, but this time used two head gaskets. I used to watch him farm with it. WOW! He bough a 600 but said it was a wimp compaired to the LA.
